1996 Ford Explorer 4WD lights on dash keep turning off and
KENNY1990
  • 1996 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 162,000 MILES
The 4wd lights on the dash by the speedometer keep flashing at random times
i dont know if it is a sensor or what but we have checked the switch and the grease
what else could it possibly be?
Friday, December 12th, 2008 AT 8:28 PM
DAVE H
  • 13,384 POSTS
Theres a fault on the ESCM you need to have it read for fault's
Electronic Shift Control Module
This module controls operation of transfer case, using inputs from 2WD/4WD selector, vehicle speed sensor, shift position sensor and transmission range sensor or clutch switch. Electronic shift control module is located in right kick panel. Module is equipped with a self-test capability.
If all conditions are correct, electronic control module will signal electric shift motor to shift gear positions. After shift takes place, module will read input from shift position sensor to determine if transfer case is in desired position. Control module will then illuminate push button and dash indicator light.
Friday, December 12th, 2008 AT 8:46 PM
