Transmission problem
1996 Ford Explorer Four Wheel Drive Automatic
My 16 year old son had a 1998 Ford Explorer(2wd sport) and had an accident that bent the frame. Someone gave him a 1996 4x4 explorer that needed a motor. Since the motor in the 2wd was in good shape, my Dad put it in the 4x4. It was fine for awhile and then the transmission went out. So, Dad put the trans from the 2wd in, however, it will not shift properly. Are there any tips that you can suggest or is it a hopeless case?
Jan 28, 2010 at 1:58 AM
