1996 Ford Explorer 1998 Mountaineer
JDPULLOUT
Transmission problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
Greetings, I was wondering if the transmission from a 1998 Mercury Mountaineer wiould fit in a 1996 Ford Explorer? If so, are the electrical connections the same?
Mar 6, 2010 at 2:33 AM
RACEFAN966
  • 5,029 POSTS
Well as long as they both are the 4R70W then yes they will interchange otherwise if they are not the same trans then no. See there is a 4R44 in 96 and a 4R55 in 98 that don't interchange. Hope this helps.
Mar 8, 2010 at 12:56 AM
