[quote:ab12a185ce="Jacobandnickolas"]Hi:
The copy you made is too small to read. Can you explain the problem?
Joe[/quote:ab12a185ce]
Sorry, here it is below. My problem is similar to this one. My truck, however, fixed itself overnight but if it did it once it will do it again. The previous answer was something is wrong in the transfer case. Do yo agree with that?
"My explorer will not go into gear, I turned off my 4x4 last night and when i didi it made a buzzing noise! I tried to turn my 4x4 on again but it just made the same buzzing noise in the rear. i then tried to put it in drive and it would not move, I then tried to put it in any gear and it still would not work. i then put it in park and there was a grinding noise like you would hear in a manual tranny that had missed the clutch. and slowly stopped grinding. I checke the tranny fluid and it was fine. I had it towed home and when the driver took it off the lift it started to roll away while in park!!!!.
Jan 14, 2009 at 9:08 AM
