[quote:16d60cc1b1="phntmfoot"]Engine Mechanical problem
1995 Ford Explorer 6 cyl Four Wheel Drive Automatic 148000 miles
When I turn the key on my truck, the fuel pump kicks on but never shuts off and doesnt start the vehicle. Per some obviously bad advice, I replaced the fuel pump. (after the fuel filter) I keep being told about a green fuel relay that could be the problem but cant find it to save my life. When the problem first came up i could shake the truck and get the fuel pump to turn off and the car could start. Not that little trick doesnt even work. Also, it will start if I spray carb cleaner into the intake but ionly until it burns that off. Thanks for your help.[/quote:16d60cc1b1]
You said your truck fuel pump runs all the time with the key on. Is it a truck or a ford explorer. Two different things. ford explorer fuel pump relay is grounded by the PCM. Maybe you need to check to see if you also have spark at the spark plugs. If not you need a test light or noid to check the injector circuit to see if it operation. With a test light test check one of the injector plugs for a completed circuit.
Take the test light put one end in one side of the plug and the other in the other side. Have someone turn the engine for you and see if the light flashes If no spark and no circuit at injectors and pump running all the time. I would expect your PCM is Bad.
Badbo
Aug 27, 2008 at 1:53 PM
