1995 Ford Explorer Whining in Reverse only
181,230 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMBODKINS
I just bought a 95 explorer 4.0 with 4wd I have been driving the truck just fine with no problems. Tonight my wife and I went to go to dinner and the truck will not go into reverse at all. It just makes a real fast whining/grinding noise. I pushed it into the driveway and drove it in drive and everything was fine but as soon as I stopped and put it in reverse it does the same thing. I can only go forward right now. What is happening. It drive perfect until I washed it.
Jul 26, 2008 at 8:06 PM
MERLIN2021
  • 17,250 POSTS
If it had reverse till you washed it, have a look at the electrical connection at the tranny, get any water out of the connector, and put some dieelictric grease in the connector.
Jul 27, 2008 at 12:09 AM
ADAMBODKINS
well after tinkering around for about an hour I figured it out. I had the 4wd knob slightly turned between 2wd and 4wd auto I must have bumped it from amoral but it is betternow
Jul 27, 2008 at 12:20 AM
MERLIN2021
  • 17,250 POSTS
Sometimes we do get lucky!
Jul 27, 2008 at 1:27 AM
