1995 Ford Explorer what does alll this mean
195,432 MILES • 6 CYL • 4WD • AUTOMATIC
DONTANORE
Egr signal out of range, No tachometer input to processor spout, cylinder ID circut fault, egr valve not opening exhaust pressure high or egr signal high, and incorrect 2nd gear ratio
Jan 11, 2010 at 2:32 PM
  • 110,251 POSTS
With that many codes, start by making sure the wiring harness to the computer is tight and not corroded. Some of them tie together, but most don't.
Let me know what you find.
Jan 18, 2010 at 6:10 AM
