water pump replacement ?
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
MACK565
what kind of gasket sealer do i use
Jan 22, 2009 at 1:09 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. I would recommend using Permatex brand Ultra Blue or Ultra Black as a gasket sealer. I've attached their pictures below. Here also is a tutorial showing how to replace a water pump:
https://www.2carpros.com/articles/water-pump-replacement
You will need to remove the serpentine belt to gain access for removal of the water pump. Here is a tutorial as well showing how to remove and replace the belt:
https://www.2carpros.com/articles/replace-serpentine-belt
I've attached picture steps below showing how to replace the water pump on your vehicle. Hope this helps and thanks for using 2CarPros.
Aug 5, 2021 at 3:42 PM
