1995 Ford Explorer Transmission
168,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHELLY7309
when driving the explorer i hear a roaring sound it will not pick up speed but as i continue to press the gas it will finally kick/jeck and then pick up speed. then a few minutes later it starts all over doining the same thing. please help what could this be
Feb 17, 2008 at 11:59 PM
MERLIN2021
  • 17,250 POSTS
TSB# 97-11-11 for 4R70W tranny states...erratic or prolonged 1-2 shift.
94-97 Mustang and others...Replace the cast aluminum piston with the one piece stamped steel piston with bonded lip seals and replace the top accumulator spring. This is due to 1-2 accumulator bore scuffing the revised piston can be used in the scuffed seal bore.
Don't know if this pertains to you or not...What speeds are involved?
Feb 18, 2008 at 12:03 AM
