1995 Ford Explorer third brake light
1995 FORD EXPLORER
PJMAC61
Electrical problem
1995 Ford Explorer 6 cyl Four Wheel Drive Automatic
How do I replace the third brake light on a 1995 ford explorer ?
Dec 4, 2008 at 12:46 AM
RACEFAN966
  • 5,029 POSTS
There should be a cover that pops out that is in the trim plastic that will give you access to the bulbs. You will probably need to twist the socket then pull it out to replace the bulb. Thanks
Dec 4, 2008 at 2:30 AM
