First do you have transmission cooler lines in the radiator? If so check your transmission fluid level and see if their is antifreeze in it.
Next you should replace the collapsed hose, that can cause a overheating problem and irratic temperature, also a bad coolant temp sensor or coolant temp sending unit could cause fluctuating temperature, along with a low antifreeze level,
have you found this red mud when flushing out the system? Or weird colored antifreeze, if not dont worry about it.
SPONSORED LINKS
Thursday, January 3rd, 2008 AT 7:48 PM
