1995 Ford Explorer strut mounts
1995 FORD EXPLORER
189,000 MILES • 6 CYL • 4WD • AUTOMATIC
HORSESHUR
need to replace tell me how
Sep 29, 2010 at 3:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Mount the new strut mount on the old mount assembly and torque down to make the spring immobile. This will allow for proper installation of the new strut mount without the spring being in the way or causing possible injury.
Look at how the holes are lined up before torquing the nut. It is important to make sure everything is lined up correctly, so that when the upper strut nut is torqued into place, no damage occurs and the mounting is all flush.
Use a vice to hold the strut mount steady so it does not move while torquing the nut down. This will also prevent the damage explained in Step 2 and offer assistance while you torque the nut down.
Torque the upper strut nut down according to your vehicle specifications. These may vary depending on make, model and year. If you are unsure about the specifications, consult with your local auto parts store associate. Remove the vice.
Sep 29, 2010 at 8:13 AM
