The motor cranks at startup but does not start the engine. The battery looks ok and it also has gas in the engine. The spark plug connection is OK. I had a check engine sign for a while and I think it is due to Oxygen sensor that i am planning to change. I will appreciate if you give me a clue what to change to fix this problem.
Jun 20, 2010 at 4:05 PM
