1995 Ford Explorer Starting Issue
198,850 MILES • 6 CYL • 2WD • MANUAL
IFTEKHAR2010
The motor cranks at startup but does not start the engine. The battery looks ok and it also has gas in the engine. The spark plug connection is OK. I had a check engine sign for a while and I think it is due to Oxygen sensor that i am planning to change. I will appreciate if you give me a clue what to change to fix this problem.
Jun 20, 2010 at 4:05 PM
  • 75,988 POSTS
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 20, 2010 at 4:14 PM
