1995 Ford Explorer sputtering
IYAOYAS_AO
  • 1995 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 140,738 MILES
Starting the truck is no problem but when I put it into drive the truck starts to stutter. When I step on the gas it stutters. When I stop you can still here it stuuter but I notice the rpms go down from a 1000 to 500 then back up again. Excelerating is no problem and there is no performance issuse (as of yet) I have replaced the fuel pump and the o1 and o2 sensors. Any ideals?
Tuesday, May 26th, 2009 AT 1:53 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Try cleaning the throttle body and remove the Idle Air Control Valve clean also. If deposites are there it will effect idle but not the overall performance.
Let me know
Thanks for donate
Tuesday, May 26th, 2009 AT 2:15 PM
