1995 Ford Explorer shifting funny
16,400 MILES • 6 CYL • 2WD • AUTOMATIC
RICK NORTH
my explorer is shifting back and forth after it gets hot. od light and check engine light was coming on and off quite a bit but changed the speed control and that seemed to help. came on again today after a short road trip. doesnt do this all the time. could it be a sensor and if so which one? afraid if i take it to a shop they will tell me i need a new tranny.
also my check engine light would come on at 70mph. never under that speed before i changed the speed control.
this shifting problem started after i washed my under carriage because of the salt on the road.
Feb 16, 2008 at 2:41 AM
MASTERTECHTIM
  • 4,750 POSTS
it sounds like you blew the vacuum hose off the transmission modulator valve. look at the transmission on the pass side right above the cat converter on the side of transmission there is a vacuum hose that connects to a valve that is connected to the trans. check that and get back to us.
Feb 16, 2008 at 3:27 AM
