1995 Ford Explorer rev motor it dies out
187,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOE BROOKINS
My suv will only idle,it dies out when i try to rev up the motor even if i just pat the gas pedal. I checked the fuel system and the psi was correct with just the key on and also when it idled. I changed out the map sensor ,did not help. I tried to hook up a tester to read the codes but it would only tell me that there was a linking error.Now i am stuck not knowing what to do . Any suggestions ?
May 19, 2010 at 8:26 PM
  • 75,988 POSTS
Clean the mass airflow sensor with an approved cleaner and test the throttle position sensor and crankshaft position sensor-
May 19, 2010 at 9:34 PM
