Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Brakes
Rotor
Replace/Remove
1995 Ford Explorer replacing the driver side rotor
1995 FORD EXPLORER
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
RISARUBY1
MEMBER
1 POST
I was able to replace all rotor except for the driver side rear rotor, we can't get if off.
Mar 7, 2010 at 2:36 AM
Experienced Mechanic
Have you tried using a dead blow hammar? If so, you may need to heat the rotor to get it off.
LEt me know.
Mar 8, 2010 at 2:49 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
