1995 Ford Explorer replacing motor with older vehicle motor
1995 FORD EXPLORER
JIMSWICKED
Engine Mechanical problem
1995 Ford Explorer 6 cyl Four Wheel Drive Automatic
i am putting the motor out of a 1991 ford explorer 4.0 L into a 1995 explorer that also had the 4.0 L i need to know how or what has to be done to make the motor mounts work
Aug 29, 2010 at 2:51 AM
  • 110,244 POSTS
We only recommend direct fit replacement parts. When you change years, you end up with trouble.
As far as the motor mounts, you should be able to remove the original mounts and switch them.
Sep 1, 2010 at 4:13 AM
