1995 Ford Explorer Power Steering Problem?
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAVAF
I have a 1995 Ford Explorer, and when I turn, the steering wheel shimmies and shakes. I checked the power steering fluid and it is full. Could this be a problem with the pump?
Thanx
Aug 15, 2008 at 1:15 PM
MERLIN2021
  • 17,250 POSTS
Bad pumps usually whine, this could be the steering column itself, and if it is, it's not real safe to drive, have it looked at quickly!
Aug 15, 2008 at 1:25 PM
SERVICE WRITER
  • 9,123 POSTS
Was it in the air latley? Up on a lift that is?
IF so drive it a few days and it should be fine.
IF not, there may be air cavitation in the pump which may be able to be drawn out. But if not, then the pressures in the lines should be checked for excessive pressure.
Aug 15, 2008 at 1:26 PM
JAVAF
I just recently had my fuel pump changed so im assuming it was up in the air because before i took it to the shop to get the fuel pump done it steered fine. Do you still believe this is dangerous to drive? Thanx for your quick response.
Aug 15, 2008 at 3:17 PM
JAVAF
Hey I took your advice and drove it around a bit and it quit shaking. Thanx for your advice and I really appreciate the quick responses. Just one question, why did it do that? Thanx again!
Aug 15, 2008 at 4:15 PM
SERVICE WRITER
  • 9,123 POSTS
I'm not sure why it does it. Every once in a while it happens. First time I ran into it I freaked out trying to figure out what the heck happened, but it went away while driving, and thats how I handle it now.
Aug 15, 2008 at 11:29 PM
MERLIN2021
  • 17,250 POSTS
Good worp P... I havent run into this one ..YET! My guess is the tires tip in, when up in the air.
Aug 15, 2008 at 11:47 PM
SERVICE WRITER
  • 9,123 POSTS
Do you think it is a separation in the suspension? Ball joints stretched out? struts? lol. I'm really at a loss to understand it. I can't see how the power steering would be affected.
Aug 15, 2008 at 11:53 PM
MERLIN2021
  • 17,250 POSTS
As Spock once said "unknown Captain!"
Aug 16, 2008 at 12:12 AM
