1995 Ford Explorer Power Steering
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
STEP2TX
Hello, I was hearing whining in the steering.....so replaced the power steering pump. Turned smooth as a new car...but after sitting overnight....it is hard to steer now and the whining is back. Noticed that the fluid looks black. Do I need new rack? or just a fluid change?...how do I empty the fluid? Thank you for any help you may be.
Aug 4, 2008 at 4:08 PM
MASTERTECHTIM
  • 4,750 POSTS
to flush out the old fluid you can remove the return line to the pump and put it in a bucket and then keep pouring fluid into pump while running engine until the fluid is clear.
Aug 5, 2008 at 11:28 PM
