1995 Ford Explorer OVER DRIVE LIGHT
189,502 MILES • 6 CYL • 4WD • AUTOMATIC
BOBSUE
HI GUYS,, IM BOBBIE AND I NEED HELP PLEASE ... ON MY EXPLORER THE OVER DRIVE KEEPS BLINKING ON AND OFF ON AND OFF ..ALL THE TIME ....AND MY CHECK ENGINE LIGHT COMES ON SOME TIMES ...I JUST GOT IT FROM A FRIEND ...SO PLEASE CAN YOU TELL ME WHAT TO DO TO FIX IT PLEASE ...THANK YOU AND HAVE A GOOD DAY OR NIGHT ,.....FROM BOBSUE FROM HANFORD CA
Dec 10, 2008 at 4:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
To better assist you, could you please get the codes from the check engine light pulled? A local part store such as AutoZone will do this for free. Post the codes you get and I will follow up.
The flashing OD light is a warning that there is something malfunctioning in the transmission system. This can be due to a simple sensor, or something much more complicated as a pressure problem inside the transmission. You should have a reputable tranny shop run a diagnostic test to see what is causing this, as driving it in this condition can lead to complete transmission failure.
Dec 10, 2008 at 6:30 PM
