1995 Ford Explorer Oil Pressure
ANOBEL84
  • 1995 FORD EXPLORER
Engine Performance problem
1995 Ford Explorer 6 cyl Four Wheel Drive Automatic
My oil pressure gauge reads zero. The oil tank is full and the oil was changed eight weeks ago. I have noticed in the past four weeks that the gauge has been fluctuating and reading a little low, but it would go back to normal after I drove for about ten minutes. Now the needle doesn't move.
Tuesday, February 23rd, 2010 AT 8:31 AM
  • 109,901 POSTS
When at 0psi, do you hear any knocking or ticking from the engine? If so, do not run the engine. If you don't hear any noise, replace the oil sending unit. It is a cheap part and easy to replace.
Tuesday, February 23rd, 2010 AT 1:30 PM
