1995 Ford Explorer Like riding in a boat...
1995 FORD EXPLORER
137,000 MILES • 6 CYL • 4WD • AUTOMATIC
FULLERSNAK
Recently I noticed that my truck is rocking back and forth while cruising down the highway. I've experienced this before when I had low tire pressure, so I've double check all 4 and it's good. I then put it up in my garage and found a 8"-10" bar hanging just behind the front tire. The top has a hexagonal bolt head with a black bushing on top, the bottom looks like it has been sheered off, but I can't see where from. I've not noticed any other issues with steering or handling. I can't find any diagrams on the web, and I have no idea what these are. Ideas?
Thanks,
Mar 20, 2009 at 3:45 PM
JGAROFALO
  • 489 POSTS
Your front stabilizer bar link has broken from its mount. There is a hole in the lower control arn for the mount. The link that is broken consists of a long bolt with rubber cushions at the top and bottom of the link - two on top, and two on bottom for a total of four.
Mar 23, 2009 at 12:09 PM
