1995 Ford Explorer It cranks but will not start
JULIEJUICE
1995 Ford Explorer 4 cyl Two Wheel Drive Automatic
hi i have had my explorer for quit a while and it always has givin me problems it starts then doesnt sometimes then in a couple days it starts again this time its been like two weeks and it still hasnt started we replaced the battery and now one of our friends are saying its probably the fuel pump. except we dont know where the fuel pump is located to check if it is or isnt. it seems to have a pattern of not being able to start either after we run the ac or the heater for a while or its parked on the hill or maybe even the weather gets to hot or cold oh and after i fill it up with gas. can you please help me.
Dec 16, 2009 at 6:21 AM
  • 110,248 POSTS
I would be glad to help. First, an easy way to check if it is a fuel related problem is to try starting it using starting fluid. If it starts for a few seconds, then you are not getting fuel. Also, you can check for fuel pressure. Here is directions how and a video. You will need a fuel pressure gauge to check it. Most parts store will lend or rent them to you.
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Next, if the car doesn't start with the starting fluid and you have good fuel pressure, I need you to check for spark to the spark plugs. Here is a how to for that:
http://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Once you have done these tests, let me know what you find so I can further guide you, and thanks for using 2carpros.com.
Dec 18, 2009 at 5:21 PM
