1995 Ford Explorer hose hanging down
67,000 MILES • 6 CYL • 4WD • AUTOMATIC
CAPTAINJPM
I have a 1995 Ford Explorer 4 wheel drive. On the front differential there is a hose about 24" that comes off the back upper right side of the differential. I came off and was hanging down. Its still connected to the differential but where does the other end go.
Mar 14, 2008 at 2:30 AM
2CARPRO JACK
  • 11,533 POSTS
That is most likely the vent for the diff. It should attach to something as high as possible without any kinks in it, so that if you go in water it cant get in the diff
Mar 15, 2008 at 1:21 AM
