1995 Ford Explorer Heater coil problems
HOGEYEMAGEE
  • 1995 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 180,000 MILES
I have an internal water leak that releases water and antifreeze out of a sidewall spout. The water is being released from what appears to be a safety spout at the front end of the dash on the inside of the engine compartment. The leak was slow at first but now has gotten to be so bad that the truck is not safe to drive. I believe that the heating coil needs to be replaced. Does this seem to be the problem? Is it something that a novice can replace on his own? What problems can I expect if I attempt this repair?
Should I leave it up to the professionals? If so, how much can I expect to pay for such repairs.
Thanks.
Thursday, February 11th, 2010 AT 8:22 AM
  • 109,885 POSTS
If it is coolant you are getting the car, it does sound like the heater core. It is an involved process to replace one. If you are not comfortable with working on cars, I would recommend getting a repair manual that has step by step instructions and pictures to help identify parts.
If you have other questions, let me know.
Thursday, February 11th, 2010 AT 10:28 AM
