headlight low beams dont work only my high beams
128,000 MILES • 6 CYL • 4WD • AUTOMATIC
LIL_AL_1971
my low beams dont work only my high beams i checked the fuses there fine the relays fine i replaced the dimmer switch still nothing an i replaced the bulbs what could it be
Nov 26, 2008 at 12:37 AM
DAVE H
  • 13,383 POSTS
the headlight'd are controlled by the DRL module ... check the wiring & fuse #15 in underhood fuse box ?? Daytime Running Lights (DRL) Module Behind left headlight. See Fig. 1
https://images.2carpros.com/forum/automotive_pictures/266999_drl_1.jpg
May 10, 2021 at 6:25 AM
