Low beams work but highbeams do not. When you pull stem to flash highbeams or push stem to put high beams on, all headlights are dark. Fuses ok, bulbs ok. Is there a relay or does the switch directly contrl the low/high beam selection?
Jan 20, 2010 at 6:01 AM
