1995 Ford Explorer fuel pump
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
DONLYGIRL25
just purchased a 95 explorer that has been sitting for over a year. Think the fuel pump may be out and wondered if it was the reset switch or the fuel pump. Will turn over with starter fluid. Can't locate the reset switch and wonder if we should replace the pump?
Apr 16, 2009 at 2:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
first may want to inspect fuel pump relay located in power distribution block under hood. also inspect inertia fuel shut-off switch located behind right front kick panel.
Thanks for using 2CarPros.com!
Apr 16, 2009 at 3:15 PM
