Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Warning Lights
Check Engine Light
1995 Ford Explorer ford 1995 explorer check engine light on
1995 FORD EXPLORER
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
JENNIFER_C83
MEMBER
1 POST
ford 1995 explorer check engine light on and improper transmission funtion its a tsb how do i go about getting it fixed is it expensive
Jun 12, 2010 at 9:55 AM
Experienced Mechanic
If there is a TSB on the problem, you need to contact a dealer. It may have turned to a recall if the problem is bad enough.
Jun 14, 2010 at 8:33 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
