1995 Ford Explorer ford 1995 explorer check engine light on
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
JENNIFER_C83
ford 1995 explorer check engine light on and improper transmission funtion its a tsb how do i go about getting it fixed is it expensive
Jun 12, 2010 at 9:55 AM
  • 110,251 POSTS
If there is a TSB on the problem, you need to contact a dealer. It may have turned to a recall if the problem is bad enough.
Jun 14, 2010 at 8:33 AM
