1995 Ford Explorer Fan Blower motor
1995 FORD EXPLORER
209,000 MILES • 4 CYL • AWD • AUTOMATIC
CODYEXPLORER95
I have a Ford Explorer 95' Eddie Bauer edition with 209,000 mile and i am have a problem with the Fan blower motor for heat and A/C. for some reason when i have the car off the fan blower stays on but if i take out the 50 amp fuse in the distrabution box it turns off. i thought it would be the relay and i found it in the front right compartmen of the car by the right head light, it was there but when i opened it up there was only 1 relay . so i pulled the only relay out and put the 50 amp fuse back in and the fan still turned on even tho the truck was off. Can u tell me what might be the problem be and what part i might need to fix it. thanks.
Nov 12, 2009 at 11:07 AM
Check and test the blower motor relay could be sticking closed-
Nov 12, 2009 at 11:16 AM
