1995 Ford Explorer Cold Start Miss
DOBSLOB1
When cold, right after start up, the engine in my 1995 ford explorer seems to miss for a few seconds then clears up on its own. It has the OHV 4.0 w/ a 5 speed; odometer reads 110,000 approx. No engine codes. It seems to happen when it sits overnight. I'm worried that an injector is slowly leaking and flooding one cyl. while it sits. Any thoughts? Thank you.
Oct 17, 2007 at 7:09 PM
MERLIN2021
  • 17,250 POSTS
Check the ECT (electronic coolant temp sensor) It's like a choke for SEFI engines...
Dec 21, 2020 at 3:29 AM
2CARPRO JACK
  • 11,533 POSTS
Could very well be an injector, pull plugs and look for any that look richer(dark) or leaner(light)
Suggested Repair
Check the engine coolant temperature (ECT) sensor, which acts like a choke on this SEFI engine. Also pull the spark plugs and look for one that is darker (rich) or lighter (lean), which could indicate a leaking injector.
Conversation Summary
A 1995 Ford Explorer with the 4.0 OHV and about 110,000 miles misses for a few seconds after a cold start, then clears up, with no codes. The owner suspects a leaking injector after overnight sitting. Experts recommend checking the ECT sensor and inspecting the plugs for a richer or leaner cylinder.
