1995 Ford Explorer engine
18,000 MILES • 6 CYL • 4WD • AUTOMATIC
ERVIN21
I did a tune up, but the ingine still shakes only in drive D or in reverseR in neutral the engine is fine, the muffler has to be change , idk wht is wrong
Oct 5, 2010 at 12:21 PM
  • 110,248 POSTS
The idle is lower in gear. Have you checked for vacuum leaks? Has the check engine light come on? Have you checked fuel pump pressure as well as the fuel pressure regulator?
Oct 6, 2010 at 12:11 AM
