1995 Ford Explorer Dome lights stay on
275,000 MILES • 6 CYL • 4WD • AUTOMATIC
JWD1010
Dome lights stay on.
I can not locate the door switch on any door to fix the problem
Oct 24, 2008 at 10:41 AM
MASTERTECHTIM
  • 4,750 POSTS
spray wd 40 onto all door latches then open and shut them a bunch of times, especially on the doors that are least used. clean out any grease if there is any. there is a little switch located on the latches that sticks causing the light to stay on. wd40 usuallly fixes it. hope this helps
Oct 24, 2008 at 11:30 AM
