Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Fuel System
Fuel Pump
Location
1995 Ford Explorer control modual
1995 FORD EXPLORER
230,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIMINOHIO2010
MEMBER
which modual is it that controls the fuel pump feed to the injectors and where is it located
Aug 19, 2010 at 4:54 AM
BLUELIGHTNIN6
Experienced Mechanic
The powertrain control module (PCM) which is located in the right rear of the engine compartment.
Aug 19, 2010 at 8:54 AM
JIMINOHIO2010
MEMBER
its not located there is is located on the right side front next to radiator
Aug 24, 2010 at 3:43 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
