1995 Ford Explorer clutch
1995 FORD EXPLORER
TOM SANDHU
Transmission problem
1995 Ford Explorer 6 cyl Four Wheel Drive 180000 miles
I had aclutch kit put in when I had the engine replaced one and a half years ago. Now I am experiencing problems with trying to put the vehicle into 1 or 2nd gear and grinding of the gears when I try to put it into reverse.
Nov 27, 2008 at 9:22 AM
  • 31,937 POSTS
Hi there,
This may be a hydraulic problem, check the clutch fluid for leaks, try a re bleed if that fixes the problem, check and replace the leaking slave or master cylinder.
mark (mhpautos)
Nov 27, 2008 at 10:41 AM
