1995 Ford Explorer CHECKING ENGINE LIGHT ON AND RUNNING
WALTER1963
Other Category problem
1995 Ford Explorer V6 Four Wheel Drive Automatic 129000 miles
Hello I would like to ask a question how to get ride of the checking engine light on and when I am driving the cars havs a noise under my feet and make little hard to speed I already change the oil, the air filter, trasmision fluid and filter when I am driving 70 miles by hours apper that noise under the car.
Thank you,
Walter
Dec 9, 2007 at 10:17 AM
BMRFIXIT
  • 19,053 POSTS
[quote:cb61dcc66b="walter1963"]Other Category problem
Thank you,
Walter[/quote:cb61dcc66b]
If you to disconnect the battery the light will go off
But it may or will return if the cause not fixed
Have it scanned for codes
Noise
check radius arm bushing
Or cat converter / shield
Dec 9, 2007 at 10:21 AM
