Hello, I just replaced the fuel pump (entire assembly) and now my gas gauge is stuck past full. I would like to prevent pulling the tank again so I'm hoping there are some things I can check before that. The new assembly I put in is a direct Ford replacement (sending unit, pump, float, etc.). Thank you in advance for your answers!!
Sep 30, 2010 at 5:29 AM
