wipers don't work. How do I check the fuses?
What do I do?
Dec 8, 2008 at 9:14 AM
✓Experienced Mechanic
Hi:
check the owners manual for fuse location. Remove the fuse and inspect it. If the internal wire is broken, replace it. You can also check continuity if you can see the wire.
Dec 9, 2008 at 8:14 AM
