1994 Ford Explorer window motor
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIGERAG
how do you replace a window motor
Apr 19, 2009 at 11:03 AM
JGAROFALO
  • 489 POSTS
[quote:54de09a93a="tigerag"]Interior problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic 149000 miles
how do you replace a window motor[/quote:54de09a93a]
Remove the interior door trim. You should find 3 access holes (about 3/4" diameter) in a triangular pattern somewhere near the lower center of the door. Some models did not have the access holes, and had only dimples in the same location. Behind the holes (or dimples) you will have three 8mm bolt heads. Remove these bolts, and unplug the electrical cable from the motor. Reverse the procedure to install the replacement motor, being careful to fully register the motor into the window mechanism before tightening the bolts.
IF the access holes are only dimples, you will need to drill them out with a 3/4" hole saw.
Apr 20, 2009 at 10:37 AM
