1994 Ford Explorer water pump
JMFORD
Engine Cooling problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
removal of fan from pump
May 26, 2009 at 6:00 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_ford_explorer_fan_1.jpg
Hope this helps?
Oct 9, 2018 at 11:51 AM
OEFCOUNTRY
Removing the fan can be a pain. You need to have a big adjustable wrench and 10mm most likely. Take 3 bolts out of the pulley. You are going to use the remaining bolt to hold the pulley in place with the 10mm. Be carefull some models have the clutch nut threaded counter clockwise.
OBXAUTOMEDIC
  • 3,718 POSTS
Hello, Check your local rental store for the following tool....
https://images.2carpros.com/forum/automotive_pictures/188069_24947_9.jpg
It will make life a lot easier. .
