1994 Ford Explorer VENTS
TFURTER
Air Conditioning problem
1994 Ford Explorer 4 cyl Front Wheel Drive Automatic
now that i'm using the air the 4 main front vents has very little air coming out why is that?
Apr 17, 2010 at 3:06 AM
  • 110,251 POSTS
Chances are there is a vacuum leak under the dash. THe vents are actuated by vacuum. If there is a leak, they won't work properly. Check that out. If you have the engine running, you may get lucky and hear a hissing sound.
Let me know what you find.
Apr 23, 2010 at 10:57 AM
