1994 Ford Explorer trouble codes
JOHNTHYGESEN
  • 6 POSTS
Engine Performance problem
1994 Ford Explorer 6 cyl Automatic
Goodmorning,
I took the truck for a drive. It was alittle rough when starting, then smoothed out. It ran great for about 5miles, then the check engine light came on. I had the ac on going 55 with cruise control on still seemed fine. I went another 5 miles then to a stop sign. the idle was at about 500 and lopping a little. I drove home but it would miss alittle if i got on the accelerator.
I have just ran the code reader on the truck and here they are: 327, 336, 337, 542. I replaced the tps last night. Is there ground problem ? the truck ran fine before the mechanic install the engine.
please help
I will donate, it will just have to wait for my check. And do I donate to the site or the person helping me?
Oct 21, 2009 at 5:00 AM
CARLIFE65
  • 200 POSTS
the code that came up, 327- is a bad knock sensor, number-1 circuit low input. code 336-crankshaft position sensor A circuit range/performance, out of adjustment,or it could be bad. code-337-crankshaft position sensor A circuit low input. code 542 intake air heater A circuit is high
https://images.2carpros.com/forum/automotive_pictures/420105_00126_knock_sensor_3.jpg
https://images.2carpros.com/forum/automotive_pictures/420105_00111_su148_crankshaft_position_sensor_1.jpg
https://images.2carpros.com/forum/automotive_pictures/420105_00372_intake_air_temperature_sensor_1.jpg
this is what the parts look like
Oct 25, 2009 at 8:33 AM
