1994 Ford Explorer transfer case motor
139,000 MILES • 6 CYL • 4WD • MANUAL
RONPA
  • 16 POSTS
I have changed the transfer case motor , Installing a reman from napa . the lights in the 4x4 selector buttons worked until I removed the original . I had my wife push the button while I was under the vehicle to see if the original motor was operating , it wasnt . I continued installing the new motor , when finished the indicator lights wouldnt come on and the 4x4 wouldnt engage . I went back and removed the transfer case motor checking my work , reinstalled the motor cleaning the ground at the bracket at the end of the motor . I checked the power cable with a multimeter doesnt seem to be any power in the cable , I also checked the high output fuse under the hood it isnt blown .
Dec 31, 2008 at 11:13 PM
RONPA
  • 16 POSTS
Well I have now installed a new control module and still nothing , The lights on the dash come on when u push the button but they are very dim ,and go out unless u hold the button in , #7 fuse good , 20 amp electric shift fuse good , new transfer case motor and new control module . What else ?
Jan 8, 2009 at 5:29 AM
RONPA
  • 16 POSTS
I also hear a slight clicking noise back by the module when I engage the button . Im also pretty sure the lights were coming on dim before the module chaange , but I convinced my self they werent .
Jan 8, 2009 at 5:37 AM
