1994 Ford Explorer tranmission
87,900 MILES • 6 CYL • 4WD • AUTOMATIC
NIC JAM35
i have a problem with my transmissoin i can back up and but i can not go in drive or overdrive or in first gear or second gear when the explorer is cold or it running it go but i f i go to the store and get back in it wont shear to drive i can back it up but not go forward so what wrong there is fliud in the transmission and it has not been chage since i had the vehicle two years now so i dont know can you tell me the problem with it
Nov 15, 2008 at 10:59 AM
BMRFIXIT
  • 19,053 POSTS
Suspect internal tranny failure
check with your local tranny shop for rebuilt tranny
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 15, 2008 at 11:12 PM
