1994 Ford Explorer starting the engine
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
NUWASIXSTRING
in the first time engine can be started. once i stopped the engine i can't start it again. after i wait for around 10 minutes engine can be started. please tell me what to do.
Mar 6, 2010 at 11:08 PM
  • 75,988 POSTS
Next time this happens don't wait for nothing do below immediately to determine whether it's a fuel or spark problem:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 7, 2010 at 11:24 PM
