1994 Ford Explorer starter
102,000 MILES • 6 CYL • 4WD • AUTOMATIC
COOLAIDE666
my explorer wont start, it just clicks one time, i replaced the starter it continues to only click one time. what things can cause the starter to not engage?
Jan 1, 2010 at 7:37 AM
  • 110,251 POSTS
Is the battery good? Also, one of the most common causes of what you described is a bad connection at the battery. Remove the battery terminals and clean and tighten them to make sure you have a good connection. Also, have you checked the starter relay? If you have a helper turn the key to the start position, check for power to the smaller wire in the starter. It should have 12+ volts.
Jan 1, 2010 at 4:47 PM
