1994 Ford Explorer starter
COOLAIDE666
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 102,000 MILES
My explorer wont start, it just clicks one time, I replaced the starter it continues to only click one time. What things can cause the starter to not engage?
Friday, January 1st, 2010 AT 3:37 PM
  • 109,885 POSTS
Is the battery good? Also, one of the most common causes of what you described is a bad connection at the battery. Remove the battery terminals and clean and tighten them to make sure you have a good connection. Also, have you checked the starter relay? If you have a helper turn the key to the start position, check for power to the smaller wire in the starter. It should have 12+ volts.
Saturday, January 2nd, 2010 AT 12:47 AM
